I am using imx8mq in android8.1. Now I want to remount /system to rw. I use the following command
1|evk_8mq:/dev/block # mount -o rw,remount /system
but the result is:
mount: '/system' not in /proc/mounts
Who can tell me how to do to remount /system?
Thanks!
Alternatively you can set both device and mountpoint to the command:
# mount -o rw,remount /path/to/the/partition /system
