How to mount data partition from NFS
cpf364
We're trying to boot Android from NFS. We're able to mount system and ramdisk from NFS. Now we're trying to mount data partition from NFS.
We're not able to do. We're not able to find any relevant information over the internet. Has anyone tried mounting data partition from NFS. Is it possible?
#nfs
cpf364
wandboard imx6 quad
Android OS : Marshmallow
diegoadrian
I found the following document, probably it could help you:
Android 6 Marshmallow over Network File System (NFS) on the Wandboard – Using Android in Industrial ...
Unfortunately, the wandboard is a third party board and we could not give further support. I suggest you go with wandboard probably they could help you better with this problem. Also, I cannot guarantee if the given information may work since we do not have a way to test it for the reason that our BSP is different from the wandboard. It is up to you if you want to test it.
I apologize for the inconvenience this may give you.
Diego.
diegoadrian
Could you please tell me which i.MX device are you using?
Diego.
