Could not open communication port (Error 0x80004005 )
mehmet_yirtar
Hello all,
I am trying to communicate the S32K144 board with either with freemaster 2.0 and 2.5, whenever I try to follow the steps at the "https://community.nxp.com/thread/464677" I got the following screens. Is there anything I am missing?
I appreciate your help.
Best regards.
Zeki
constantinrazva
Hello mehmet.yirtar@tubitak.gov.tr‌,
Could you share the model that you are using? That way it would make it simpler to get to the bottom of your issue.
Kind regards,
Razvan.
constantinrazva
And mehmet.yirtar@tubitak.gov.tr‌, could you also let us know what version of the toolbox you are using? It would be better if you could share the output of the following command (ran in MATLAB terminal)
ver
Kind regards,
Razvan.
