PCF84176 Command Strings
ted_warn_nc
HI:
I am trying t send data to the PCF85176.  I have tried the examples I found on ;line (Only 1) and have not has any success getting the displays to work.  I need to use the 7 segment mode and multiple LCDs.
Can anyone send me some sample command/data strings to turn the segments on and off?
Ted
ted_warn_nc
Hi G.w. Sun.
Thank you for you help, I will look at it and see if it will help.  I am just getting back to this section of the project.
guoweisun
HI
I attached similar product sample code for reference,hope could help you!
