KW41Z BLE Scan
Question asked by sensenthuran on Oct 4, 2019
Latest reply on Oct 15, 2019 by sensenthuran
All the iBeacon sources are close the the KW41Z (ble_fsci_black_box received  rssi ~65dBm) and all the sources  transmit iBeacons at 100ms transmit interval.
When we have  more than 3 iBeacons sources are active, then KW41Z with ble_fsci_black_box binary get all the scan results as expected.
If we enable only one iBeacon source, kw41z returns only one scan result when we enable the ble scan. Then it does not give any scan results for several minutes (1-15 mins).
If we have many beacon sources, then we do see all the scan results as expected.
Is there any filtering mechanism inside the  ble_fsci_black_box firmware?
Sen
BLE SCAN reported  every 30 mins, when only one iBecon source is present
17:58:10.772: iBeacon: rssi=-52 addrType=0 payldLen=30 major=257c minor=6e73
18:26:13.777: iBeacon: rssi=-50 addrType=0 payldLen=30 major=257c minor=6e73
18:48:09.882: iBeacon: rssi=-49 addrType=0 payldLen=30 major=257c minor=6e73
19:20:08.653: iBeacon: rssi=-51 addrType=0 payldLen=30 major=257c minor=6e73
