I am looking for an example using the uart with FreeRTOS. I was told that I can build an SDK with adding Amazon FreeRTOS for middle ware to get these examples. I could not find "Amazon FreeRTOS" anywhere on the SDK build page. Any help would be appreciated
Hi Andrew,
When you open the Select Software Components, you will find the option in operative Systems FreeRTOS.
Please look at the next exxample in your SDK
\SDK_SDK_2.2_FRDM-KW41Z\boards\frdmkw41z\rtos_examples\freertos_lpuart
Mario
