Hi Davis,
I have internally consulted about your injury, and below you can check the response:
This Arm Developer article claims: "the ARM software specification[1] followed by Linux Distributions and toolchain libraries mandates hardware floating point support at AARCH64."
So, if it is Linux on ARMv8, it is hardware floating point. And that is the reason why our toolchain does not support flags like -msoft-float.
Hope this will be useful for you.
Best regards!
/Carlos
