Curtis Lipski
interfacing MCF5480 through Compact PCI interface issues
Discussion created by Curtis Lipski on Mar 5, 2009
Latest reply on Mar 17, 2009 by Curtis Lipski
I have a system board using an MCF5480 with a Compact PCI interface to the motherboard.
Upon boot up, we are seeing bad video issues and communications problems with the board.
I feel I have the interfaced designed to the Compact PCI specifications by adding a 10 ohm series resistor n the path between the connector and cpu. This distance is within spec as well.
Has anyone seen a similar issue or have any ideas on what to do to fix this problem
Your feedback is much appreciated
