Hi community,
I am trying to develop a video source system using i.MX 6SoloX and 24bit LCD IF. I got a i.MX 6SoloX SABRE board and installed Yocto-Linux(4.14.98) on it.
I have had a MCIMX28LCD, I am able to use it by seeing following.
<https://community.nxp.com/docs/DOC-104844>
Then I ran the "fbtest"<https://github.com/jumpnow/fbtest>, I noticed that I am using a MCIMX28LCD with RGB565 format. The video data format of the system under development assumes the RGB888.
Is there a way to use MCIMX28LCD with RGB888?, or should I use another LCD?
Thank you
Solved! Go to Solution.
Hi Takashi
seems it is supported in dts file, one can check "bus-width"=24 in imx6sx-sdb.dtsi file
imx6sx-sdb.dtsi\dts\boot\arm\arch - linux-imx - i.MX Linux kernel
One can try demo images from i.MX Software | NXP
available options one can check in Table Common kernel boot parameters
Release Notes document from that link.
Hi Takashi
