MKW24D board transmitter
vitorgabriel100
Hello.
I would like to know the approximate range (in meters) of the nxp MKW24D board transmitter. I would also like an indication of an external PA compatible with this board.
Tags (3)
estephania_mart
Please consider that this device is not recommended for new designs, you can use the Hardware Design Considerations and maybe use the KW41Z Power Amplifier Reference Design | NXP to complement your design , still, I would recommend you to use the KW21Z and use as well the KW41Z reference design.
Regards ,
Estephania
