Documentation about resolution vs frame rate for s32v234
ysun1
s32v324 board.
The datasheet specifies this chip works with 1080p, 30fps inputs. Is other frame rates with different resolution supported? For example: Can I work with 640x512 format at 60 fps? or 2048x1536 at 15fps?
