CodeWarrior TAP and GDB for LS2084 debug
miha_at_work
Hello.
It is possible to debug LS2084 by Codewarrior TAP using only GDB (without CodeWarrior software)?
alexander_yakov
No, CodeWarrior TAP can not be used with GDB.
Previously, there was a project using CodeWarrior TAP with GDB, but this project is no longer supported.
alexander_yakov
miha_at_work
Ok. Thank you.
