After Change the LPDDR4 Freq get  "Synchronous Abort" handler, esr 0x96000000 Error
Question asked by Hanson Chung on Sep 30, 2019
Latest reply on Oct 14, 2019 by 传策 薛
Hi all
After Change the LPDDR4 Freq to 2000Mhz get  "Synchronous Abort" handler, esr 0x96000000 Error
U-Boot SPL 2018.03 (Sep 30 2019 - 16:01:28 +0800)
PMIC: PFUZE100 ID=0x10
DDRINFO: start lpddr4 ddr init
DRAM PHY training for 2000MTS
check ddr4_pmu_train_imem code
check ddr4_pmu_train_imem code pass
check ddr4_pmu_train_dmem code
check ddr4_pmu_train_dmem code pass
Training PASS
DRAM PHY training for 400MTS
Training PASS
Training PASS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
Normal Boot
Trying to boot from USB SDP
elr: 00000000007e5778 lr : 00000000007e56d0
x0 : 00400000000a05d1 x1 : 00400000422a0600
x2 : 0000000042200010 x3 : 00000000007fb9b0
x4 : 00000000fffffff6 x5 : 00000000000f0048
x6 : 0000000000000002 x7 : 00000000007f5400
x8 : 0000000000185c40 x9 : 0000000000000002
x10: 000000000000000d x11: 00000000ffffffd0
x12: 000000000001869f x13: 0000000000000040
x14: 00000000303100f0 x15: 00000000ffffffff
x16: 0000000000000033 x17: 0000000000000000
x18: 0000000000185e40 x19: 0000000000000030
x20: 0000000000000040 x21: 0000000042200030
x22: 0000000000000390 x23: 0000000000000387
x24: 00000000007f3178 x25: 00000000007f3160
x26: 00000000deadbeef x27: 0000000000000000
x28: 00000000000000f0 x29: 0000000000185cc0
Resetting CPU ...
i gen 'lpddr4_timing.c'  with mscale DDR tools v2.1 and build with uboot .But i get the Error?? Why??
Some Freq is working like 1600Mhz,1200Mhz and some Freq not work like above.
Hanson
