I'm trying to open a .mex file that wants to reach out and download some configuration data but it always errors saying:
"Communication error. Check the connectivity to the Internet and repeat again."
The internet works so I assume it's having trouble getting through my company's proxy. I found the preference setting for proxies and have tried both direct and native but both produce the same error. Is there a manual way to configure proxy settings when the automated native setting doesn't work, or what else could I try to fix the issue? According to IT they don't even see a proxy hit when the tool makes the attempt and errors.
I know the .mex file is good because I've been able to open it on another computer connected to an open network.
Solved! Go to Solution.
Hi Mark
one can look at below link with some explanation of proxy usage
NXP Pins Tool: Understanding Data for Offline Usage | MCU on Eclipse
Hi Mark
Thanks! That gave us enough to get it all running.
