The installation of S32 Design Studio for Power Architecture Version V2.1 has been rolled back.
marco_li
The attached file is the installation log.
Hwanmin
Hello.
Could you tell me how to check the access? I'm having the same problem. Thank you.
marco_li
The screenshot is as below:
mikedoidge
Hello marco.li@zongmutech.com‌,
In the installation instructions, it is stated that the user must have administrative access when installing S32 Design Studio for Power Architecture. Without this, there will be access denials during installation which will trigger the rollback. This is seen in the log file provided:
Install Uninstaller: S32 Design Studio for Power Architecture Version 2.1(Install All Uninstaller Components)
Status: ERROR
Additional Notes: ERROR - Error writing LaunchAnywhere components (Access Denied)
Could you please confirm if the tool was installed with administrative access enabled?
Mike
