Audio-in-out on imx6qp board
sachinarora
We are using imx6qp SabreSD eval board (with OREO 8.0) to make a call. We are able to call the other person, but "Not able to hear or speak on the mic port and audio-out port."
Kindly note that we are able to play an audio file and listen to it using the audio-out port. Also, we are able to record the audio using the mic port on the kit.
Kindly help.
Thanks and Regards,
Sachin Arora
Labels (2)
smohsin
There are a few things that could be causing this issue. First, make sure that the audio levels are turned up on both your computer and your microphone. If that doesn't work, try plugging the microphone into a different port on your computer. If you're still having trouble, it's possible that there's an issue with your sound drivers. Try updating them or reinstalling them to see if that helps. mamc
cisawohi
Hi buddy, did you get any permanent solution? As at my end the issue is more or less same. If you get any do let me know.
Cisa Smith
_________________
https://plex.software/ https://tutuappx.com/ Vidmate
diegoadrian
Have you installed in the proper way the extended media codecs?
Android OS for i.MX Applications Processors | NXP
Embedded Application Software - miscellaneous
For more detail on it, please, refers to the i.MX Android Extended Codec Release Note
Diego.
