Does i.MX6UL GPIO support tri-state?
Customer would like to pull high by external pull high resistance..
Solved! Go to Solution.
Hi m.c.
tri-state is not supported but one can use open drain, using bit
ODE - Open Drain Enable Field in IOMUXC_SW_PAD_CTL_PAD_x
register. Description can be found in Chapter 30
IOMUX Controller (IOMUXC) i.MX6UL Reference Manual.
Hi m.c.
