We are using S32V234-EVB2- SC29288, and wanted to set up LINUX KERNEL 4.19. version locally.
Please do provide documents to set up kernel source code base locally. i.e complete kernel sources, including all drivers sources, that can be modified/build image with modified kernel sources.
This is to add custom drivers and modify existng drivers in kernel.
Thanks.
Hello vaibhav.n@craftlogiclabs.com
This community space do not cover the topic you need assistance on.
Please create new NXP support case according to following procedure:https://community.nxp.com/docs/DOC-329745
I think you can find more info about Linux BSP build procedure here.
Hope this helps,
Paul
