Issue with setting receive FIFO filters in S32K148
chandru_v
If FIFO is enabled and if we try to configure receive filter we are facing inconsistency in setting some receive filters after multiple attempts we are able to set the filter particularly 24th bit please let me know what is the issue.
Alexis_A
Dear Chandru,
Could you let me know which is the value from you global mask, the RX Individual Mask and the ID you want to receive in the FIFO?
Meanwhile, I will suggest to check the FlexCAN_s32k148 example that can be found in the SDK.
I hope this helps you.
Alexis Andalon
chandru_v
Dear Alexis Andalon,
The previously discussed Issue I was able to reproduce and I have attached a screen recorded video with the mail, let me know what is the issue, for debugging also I am ready to support you.
Chandru V
Alexis_A
Dear Chandru,
It was not clear what did I see in the video, could you share your code and explain detail what is the issue?
Alexis Andalon
chandru_v
Hi Alexis Andalon,
We are not suppose to share the code as we are doing product development but we can provide you support through skype call where we can share the screen and explain the issue.
Chandru V
Alexis_A
Hello Chandru,
Unfortunately this is outside our scope, but if you could share a code where I could replicate this issue. Maybe only initializing the CAN, the ID and filters that you use I could check it.
Alexis Andalon
