32Mhz crystal for MKW41Z
jhd
In the SPF-29686_A1 the 32Mhz XTAL not use capacitors. It's ok? They are not necessary?
I plan to use this crystal with the MKW41Z512VHT4
YSX221SL
Datasheet
jhd
Finally I have done the modules, short range and large range, with the capacitors if I see that they are not necessary, I will not place them.
this image is of the long range with the sky61112, the 1206 ''capacitor'' is the ble antenna, i haven't the 3d model :smileyhappy:
Short range version
