Santosh Sethumadhava
SmartStudio Lite - Bug fix in exported optimal settings for NXP TFA amplifiers
Discussion created by Santosh Sethumadhava Employee on Sep 19, 2019
With SmartStudio Lite v3.0.60.3, a bug was discovered in the generation of the tfa_config.h file.
This bug will cause the audio performance to be sub-optimal (lower loudness) when using the generated tfa_config.h file.
Next releases of the tool will contain a fix. In the meantime, please follow the instructions in the attached updated guide
to avoid this issue.
