I have CodeWarrior for Freescale 65800/E v.8.2.3 special edition, but items "Help\Freescale 56f8xx PDF Index"- "Help\Freescale 56f83xx PDF Index" and "Help\Freescale PDF Manual folder" not work.
Is it a bag?
When you installed CodeWarrior, did you let it install the documentation?
---Tom
I additional run Install-Modify and mark "Motorola Documentation" - install feature & all subfeaturs to hard drive, but not get result.
I downloaded and installed CW Special Edition for DSC56800E v8.2.3. When specifying what to install, the installer allows me to install Freescale (not Motorola) documentation. The only files in the Help directory are a bunch of .chm, .hlp, and the occasional .xml or .htm file. The only subdirectory is PDF, which holds all of the docs as Acrobat files. I don't know what these other directories are, unless they are leftovers from a previous installation that used an earlier version of the software.
---Tom
