CCID Command/Instruction Version
sachin_singh
I am looking for the command/instruction version number used in phExCcid example "PN7462AU-FW_v05.07.01_Full" firmware example.
So, can you please help me to get the version number of CCID command/instruction used in firmware example.
Looking forward for the responses ... !
Kan_Li
Please kindly refer to https://usb.org/sites/default/files/DWG_Smart-Card_CCID_Rev110.pdf  for details.
Hope that helps,
Kan
