Light green pins in pins tool
stevenlutz
What does it mean when pins and peripherals are colored light green when starting a new project?
How do I clear everything and start from scratch?
I'm working with the twr-mke18xf
Tags (2)
Robin_Shen
Hi Steven Lutz,
If Default board files is select, then you will see pins and peripherals are colored light green.
Please try to select Empty board files.
Robin
stevenlutz
Excellent!
thank you so much!
