fsl_mcan driver dropping interrupts bug
tomasxvavra
Hello, I think that there is a severe bug in fsl_mcan.c driver (SDK2.6.0). I am using LPC54618 dev kit.
Function MCAN_TransferHandleIRQ clears all interrupt flags insted of only the "solved ones". If there are simultanous interrupts pending, then only one gets processed and others are ignored.
Problematic part is MCAN_ClearStatusFlag(base, result);
void MCAN_TransferHandleIRQ(CAN_Type *base, mcan_handle_t *handle)
    /* Assertion. */
    assert(NULL != handle);
    status_t status = kStatus_MCAN_UnHandled;
    uint32_t result;
    /* Store Current MCAN Module Error and Status. */
    result = base->IR;
    do
        /* Solve Rx FIFO, Tx interrupt. */
        if (result & kMCAN_TxTransmitCompleteFlag)
            status = kStatus_MCAN_TxIdle;
            MCAN_TransferAbortSend(base, handle, handle->txbufferIdx);
        else if (result & kMCAN_RxFifo0NewFlag)
            MCAN_ReadRxFifo(base, 0U, handle->rxFifoFrameBuf);
            status = kStatus_MCAN_RxFifo0Idle;
            MCAN_TransferAbortReceiveFifo(base, 0U, handle);
        else if (result & kMCAN_RxFifo0LostFlag)
            status = kStatus_MCAN_RxFifo0Lost;
        else if (result & kMCAN_RxFifo1NewFlag)
            MCAN_ReadRxFifo(base, 1U, handle->rxFifoFrameBuf);
            status = kStatus_MCAN_RxFifo1Idle;
            MCAN_TransferAbortReceiveFifo(base, 1U, handle);
        else if (result & kMCAN_RxFifo1LostFlag)
        else
        /* Clear resolved Rx FIFO, Tx Buffer IRQ. */
        /* Calling Callback Function if has one. */
        if (handle->callback != NULL)
            handle->callback(base, handle, status, result, handle->userData);
        /* Reset return status */
        result = base->IR;
    } while ((0U != MCAN_GetStatusFlag(base, 0xFFFFFFFFU)) ||
             (0U != (result & (kMCAN_ErrorWarningIntFlag | kMCAN_BusOffIntFlag | kMCAN_ErrorPassiveIntFlag))));
Following modified code works correctly.
    /* Assertion. */
    enum _mcan_status status = kStatus_MCAN_UnHandled;
    uint32_t interruptReq;
    uint32_t interruptReqHandled;
    interruptReq = base->IR;
    //assert(interruptReq != 0);
    do
        interruptReqHandled = 0;
        if (interruptReq & kMCAN_TxTransmitCompleteFlag)
            interruptReqHandled = kMCAN_TxTransmitCompleteFlag;
        else if (interruptReq & kMCAN_RxFifo0NewFlag)
            interruptReqHandled = kMCAN_RxFifo0NewFlag;
        else if (interruptReq & kMCAN_RxFifo0LostFlag)
            interruptReqHandled = kMCAN_RxFifo0LostFlag;
        else if (interruptReq & kMCAN_RxFifo1NewFlag)
            interruptReqHandled = kMCAN_RxFifo1NewFlag;
        else if (interruptReq & kMCAN_RxFifo1LostFlag)
            interruptReqHandled = kMCAN_RxFifo1LostFlag;
        else
            interruptReqHandled = interruptReq;
        MCAN_ClearStatusFlag(base, interruptReqHandled);
            handle->callback(base, handle, status, interruptReq, handle->userData);
             (0U != (interruptReq & (kMCAN_ErrorWarningIntFlag | kMCAN_BusOffIntFlag | kMCAN_ErrorPassiveIntFlag))));
ZhangJennie
Tomas Vavra
This issue will be fixed in next SDK release v2.7.0.
Thanks for bringing the problem to our attention.
Jun Zhang
ZhangJennie
HI Teus Verbeek
Tomas Vavra's issue has been reported internally.
Could you please create a new thread for your issue. We need separate the different issue for better track.
Thanks.
Jun Zhang
teus
We have an issue that is very simular to this one. What is looks like is that we are missing Tx interrupts in the same handler.
This results in a crash in the fsl_mcan which can only be recoverd by setting TXBAR register to 1. Then it runs for a while and it stops sending CAN messages again.
We are working with a LPC54608.
tomasxvavra
If you use my code of MCAN_TransferHandleIRQ, does it change anything for you?
teus
We did not measure any difference. Maybe it is because we already have the following construction in the Rx handler.
The above code solves a lot of trouble with the receiving part of the driver. But now (a few months later) the transmitting part is giving trouble.
We added a simular construction to the Tx handling:
This construction takes on a fraction longer but also crashes after a while.
teus
We also see after some testing that the handler is called and the interruptReq stays zero. The same scenario Tomas captured in the  assert.
But if we place a breakpoint after the copy we see that the IR register contains some interrupts.
tomasxvavra
Yes, this is another issue I have been also investigating but didn't found anything.. Iterrupt handler is called and IR register is zero, I have no idea how could this be happening.
tomasxvavra
Is original standalone mcan driver for LPC546xx (can.c) from NXP better? I am finding that SDK contains just too many bugs and its killing my productivity I used to have with NXP products..
ZhangJennie
Hi Tomas.
Thanks for letting us know. I will feed back your findings to SDK development team. I will let you know if any update.
Have a nice day,
Jun Zhang
