Hi all,
When i import a project i have errors like is described in the image attached:
-No inherited component assigned; failed to create component /template fsl_sim_hal
- program "" not found in PATH
I am using KSDK 1.2.0 and i have installed ksdk 1.2.0 eclipse plug- in. I do not know how to do... i am exhausted.
Someone can help me please?
Hi Diego,
Can you please try to import the files again and make sure the checkbox that states "Copy to Workspace" is not checked.
Please let me know if this results positive for you.
Sabina
