The command,
fb-test -f 0
generates and displays a test pattern on the screen.
But the command,
cp /home/root/test.jpg /dev/fb0
copies the test image into /dev/fb0 but fails to display anything on the screen.
How to resolve this issue?
Hi Abhijeet
one can redirect image directly to the framebuffer device as follows:
cat image > /dev/fb0
FSL-UT-FB-003.txt\doc\mxc_fb_test\test - imx-test - i.MX Driver Test Application Software
