Ahmad Syazwan
SCI on PAN82154 (GT60)
Discussion created by Ahmad Syazwan on Mar 1, 2009
Latest reply on Mar 4, 2009 by Ahmad Syazwan
Hello.
I have been stuck trying to get Serial Communication Interface on this low power module for days! Let me explain:
-PAN82154HAR00 with MCU S08GT60 (Based on SARD)
-Started with Freescale BeeKit SMAC demo: PER test
-Everything worked after some header modifications to support my module. Except nothing is displayed on my Hyperterminal. Baud rate 38.4k, 8-N-1, no flow control setting as suggested by the demo and PAN82154 data sheet. SCI COM port is set to 1
-Learnt that I need to set pin 6 of port C to high, otherwise RS-232 IC will go into sleep mode to conserve power
-Still nothing on Hyperterminal
I have tried going through the SCITransmitStr() function step by step in debug mode using CodeWarrior.  I can pretty much understand what it's doing and it appears to be sending a character at a time everytime TX buffer is empty. How can I still not see them on my Hyperterminal? Any idea what I am missing?
Really hope someone can shed some light...
