K82F based FRDM board flashing procedure
vivek_kaushik
I am using KSDK 2.6.0 for K82F based FRDM board, I am using MCUXpresso IDE.
I am able to compile all example and my own code and flash and able to test on FRDM board and everything is working fine.
I would like to know any alternative simple way of flashing binary to FRDM board instead of using MCUXpresso, as I have to share my binary with other teams, who will not use MCUXPresso IDE, if there is alternative simple flashing mechanism available for my other teams to use then I do not need to share and explain them to use MCUXpresso IDE.
Please support.
Kind Regards
Vivek
Robin_Shen
Hi Vivek,
You can drag-and-drop binary (.bin) files onto the virtual hard disk to program the internal flash of the target MCU.
Please refer: OpenSDAv2
Robin
vivek_kaushik
Thanks! a lot Robin,
It is really helpful procedure. Please let me know where in my project folder I can locate the .bin file to flash?
Kind Regards,
Vivek
vivek_kaushik
Hi Robin,
I am not able to locate any .bin after build in my project folder. However if i use MCUXPresso IDE to flash after build, I can see my modified code is getting flashed and executing.
My project folder is looking like below:
And the FRDM board when connected to my PC appears as below, is it expected?
Kind Regards
Vivek
Robin_Shen
Hi Vivek,
Please refer: MCUXpresso IDE: S-Record, Intel Hex and Binary Files
Robin
vivek_kaushik
Thanks a lot! Robin. This helps, will get back for any further support.
Kind Regards
Vivek
