Install Galcore Module in linux-4.14.126
ankitkumar_sing
I have installed Galcore as separate module for linux-4.14.126 for i.mx6dl bsp. It is not able to create device entry as "/dev/galcore" untill i disable etnaviv-drm in makemenuconfig and place older (linux-4.14.46)gpu entry in imx6qdl.dtsi.
Please provide procedure to enable galcore with gpu entry in device tree and sample gpu application to test.
Labels (2)
Bio_TICFSL
Hello Ankit,
The GPU galcore doesn´t not support the L4.14.126 it is supported on L4.14.78, you migrate as module in your kernel.
