About Boot from QuadSPI (BOOT_CFG)
Question asked by goto11@wantsinc.jp on Sep 9, 2019
Latest reply on Sep 10, 2019 by Yuri Muhin
hello,Community
The READ or WRITE sequence on the memory side during BOOT differs depending on whether the flash memory side is set to standard SPI or QSPI.
If the Boot QuadSPI configuration parameters are stored in the flash memory, how can the configuration be read from the flash memory even though the flash memory setting is standard SPI or QSPI is not known? .
best regards
Goto
