function that returns the time since nxp kw24d was turned on
vitorgabriel100
I'm using a nxp kw24d board and I want to know if exists a function that returns the time since this board was turned on. I want a function similar of millis() in Arduino.
Thanks!
Vítor Caitité
Tags (2)
estephania_mart
There is no analog function in the current examples, still, you can  try using the RTC module of the device and  configure it to get the timestamp.
You can check the chapter 47 of the Reference Manual of the device for further details on this
Estephania
