Problem in MQTT
Problem in MQTT
prasanthapplied
Dear all,
        I'm using IMXRT1064 development board and i want to use lwip mqtt example. So i tried an example which was given in SDK. While running the board getting DHCP IP and it resolves MQTT broker ip then subscribed a topic. But after that the connection gets failed. The serial window comes like
Initializing PHY...
 MQTT client example
Getting IP address from DHCP...
IPv4 Address     : 10.10.37.1
IPv4 Subnet mask : 255.255.0.0
IPv4 Gateway     : 10.10.0.202
Resolving "test.mosquitto.org"...
Connecting to MQTT broker at 5.196.95.208...
MQTT client "lwip_client-123" connected.
Subscribing to the topic "lwip_topic/#" with QoS 0...
Subscribing to the topic "lwip_other/#" with QoS 1...
Subscribed to the topic "lwip_topic/#".
Going to publish to the topic "lwip_topic/100"...
Subscribed to the topic "lwip_other/#".
Published to the topic "lwip_topic/100".
Received 18 bytes from the topic "lwip_topic/100": "message from board"
MQTT client "lwip_client-123" not connected.
after sending one or two messages it continuously says not connected. So whats may gives a problem. Please help me to find the solution?
Thanks & Regards,
Prasanth
kerryzhou
Hi prasanth R,
   I think it is also related to the web, or the MQTT broker side stability.
   Because, sometimes, when I can't connect the mqtt, I find even the mqtt.fx also lost the connection:
   I think, this is also the problem why the SDK author can't reproduce our problems in the previous time.
   So, maybe you also can create your own MQTT stable broker, and test it again on your side.
Kerry
dmarks_ls
Senior Contributor I
Make sure that you are locking/unlocking the TCPIP core prior to calling the MQTT API.  See my post here.
David R.
kerryzhou
Hi prasanth R ,
 Please tell me which SDK example you are using?
  Please give me that example code path in the SDK, then I will help you to check it.
Kerry
prasanthapplied
Hi Kerry,
   SDK Version is 2.6.1.
   Example code path is "C:\Users\AA-PDEE21\Documents\MCUXpressoIDE_11.0.0_2516\workspace\evkmimxrt1064_emwin_gui_demo"
Thanks & Regards,
Prasanth
kerryzhou
Hi prasanth R,
  Do you mean this project:
SDK_2.6.1_EVK-MIMXRT1064\boards\evkmimxrt1064\emwin_examples\emwin_gui_demo
 But this example just he emwin with LCD, it doesn't have the MQTT code.
  Please help double check it, you you really use this example?
 Or do you run this code:
\SDK_2.6.1_EVK-MIMXRT1064\boards\evkmimxrt1064\lwip_examples\lwip_mqtt
Kerry
arimendes
Kerry,
I've just downloaded the SDK_2.6.1EVK-MIMXRT1064 and I didn't find the lwip mqtt example in the path: \SDK_2.6.1EVK-MIMXRT1064\boards\ev mimxrt1064\lwip examples\lwip mqtt
Do I have to add something more than the lwip component to have lwip mqtt example?
 Ari.
kerryzhou
Hi Ari Mendes,
   When you generate the SDK, please select all the middleware component:
Then you will find the mqtt project.
Kerry
prasanthapplied
Dear Kerry,
         Already i download the SDK with all the software components.
kerryzhou
Hi prasanth R,
   The download reply if used for Ari Mendes, I know you already get it.
   Today, I have finished my test platform, I test it, and reproduce your problem, it seems, it is not stable, this is my test result:
Initializing PHY...
 MQTT client example
IPv4 Address     : 192.168.43.199
IPv4 Subnet mask : 255.255.255.0
IPv4 Gateway     : 192.168.43.1
Received 6 bytes from the topic "lwip_topic/100": "123456"
Sometimes connected, sometimes not connected, then I use the MQTT.FX to test the test.mosquitto.org, the publish and subscribe is working.
From the printf log, we also find:
Sometimes, the RT board subscribe can receive the data which is published by the mqtt.fx.
About this detail problem, I will check it with our related department, I will give more reply in the next week.
Please keep more patient, thanks.
Kerry
prasanthapplied
Dear Kerry,
This is exactly the same problem what I face. I will wait for your reply.
Thanks & regards,
Prasanth.
kerryzhou
Hi prasanth R,
     Today, I test it again on my side, this is my test result:
    You can find, it can publish and receive the data, but just sometimes, it disconnected:
   You can test it again, whether you can receive the data and publish the data again?
Initializing PHY...
 MQTT client example
IPv4 Address     : 192.168.43.200
Received 4 bytes from the topic "lwip_topic/100": "8888"
Received 4 bytes from the topic "lwip_other/10": "3333"
  About this problem, I also have talked it with our SDK testing team, they have meet the similar problem in the previous time, but after talking to the project owner, the owner didn't produce the problem.
   Now, our testing team help us to test the newest SDK again, they also reproduce the disconnect problem, they already help tol report the bug to the SDK R&D department again.
   Anyway, if I get any valuable information from our internal side, I will let you know.
   From my today's test result, at least, the code can do the publish and subscribe function, when I use the MQTT to publish the data, the RT board also can receive it. So, you can test it again.  From our original post, it seems, you can receive nothing, that really a problem, and different with my latest result.
Kerry
prasanthapplied
Dear Kerry,
I tested the same code again. Now it works fine not disconnected. I don't know how this happened. I attached a screenshot for your reference.mqtt.PNG
kerryzhou
Hi prasanth R,
Kerry
prasanthapplied
Dear Kerry,
       Okay sure i will test it on my side. Thank you very much for your help.
Thanks & Regards,
Prasanth.
prasanthapplied
Dear Kerry,
        I drag and dropped the sdk to MCUXpresso Installed SDK window the select the project using Import SDK Example which is available at the Quick start panel. then i select the board and lwip and lwip mqtt. I attached a screenshot to it.
I didn't download or install more than this.
Thanks & Regards,
Prasanth.
kerryzhou
Hi prasanth R,
    Sorry for my later reply, really a lot busy recently.
   I have checked it on my side these days, but my company's website is secured, so I can't test the MQTT project directly, I need to buy the Rounter, and use the mobile 4G through the Rounter to get the unsecure network for Ethernet, I already buy the Rounter, but still didn't receive it, maybe still need more time.
   Anyway, I will also help you to check it with our SDK testing team, this project should works, just like the readme.text test result.
  Any updated information from my side, I will let you know.
  Thanks a lot for your understanding.
TIC
prasanthapplied
Dear Kerry,
          Okay sure. Take your time and update me.
Thanks & Regards,
Prasanth.
prasanthapplied
Sorry mistakenly i updated wrong directory. The directory is "C:\Users\AA-PDEE21\Documents\MCUXpressoIDE_11.0.0_2516\workspace\evkmimxrt1064_lwip_mqtt_freertos". Please check this.
kerryzhou
Hi prasanth R,
   Thanks for your updated information, you should import the code from this SDK path:
SDK_2.6.1_EVK-MIMXRT1064\boards\evkmimxrt1064\lwip_examples\lwip_mqtt\freertos
   Could you tell me which MQTT testing server you are using? MQTT fx or others, do you connect it successfully, can you also share some screen about it?
Kerry
prasanthapplied
Hi Kerry,
        I didn't change mqtt server. I used the same what was given from an example code. mqtt1.PNGmqtt2.PNG
After first page frequently it says "lwip_client-123" not connected. But i didn't have any internet issues.
Thanks & Regards,
Prasanth.
kerryzhou
Hi Prasanth.,
   I will test this code on my side, and give you updated information later, please give me more time.
Kerry
