8M Mini RMII.TX_ERR signal
Question asked by adevries on Sep 5, 2019
Latest reply on Sep 10, 2019 by adevries
On page 41 of the 8M Mini datasheet, it says that pad ENET_TXC can be put in ALT1 mode and output signal RMII.TX_ERR. However, RMII doesn't use a TX_ERR signal. Is this a mistake? How should I be using this signal when connecting up an Ethernet PHY using RMII?
