CARLO CUROTTO
S12VR - Fill Free Memory Space
Discussion created by CARLO CUROTTO on Sep 5, 2019
Latest reply on Sep 6, 2019 by lama
Hello everybody,
I'm using the tomar microcontroller S12VR for my application.
I need to fill the flash memory not used with NOP and JMP at start up address instructions.
I have modified the .prm file with the FILL directive.
The fill directive required hexadecimal values but I don't know which are the corrispettive values.
I have tested the FILL directive with an example value (0x55) and it is work.
Could you help me?
Thanks in advance
