Ethernet MII mode issue on i.MX8MM (Applied PHY IC : KSZ8081MNX)
Question asked by Lee Jaehee on Sep 3, 2019
Latest reply on Mar 17, 2020 by vespaman
Please see the attached file for detail Picture : Ethernet MII mode issue on i.MX8MM_wKSZ8081MNX_20190904.pptx
* Applied IC
    1) Applied CPU : i.MX8MM (MAC included, possible RGMII/MII)
    2) Applied PHY IC : KSZ8081MNX (Only MII mode)
1. Symptom
    A) ping communication between [PHY]-[MAC] is impossible (MAC setting : MII mode)
   Picture A.1) : when connecting <TXC line> between [PHY]&[MAC] measuring <TXC line>
   Picture A.2) : when cutting <TXC line> between [PHY]&[MAC] and measuring <TXC line > of PHY side.
   Picture A.3) : when cutting <TXC line> between [PHY]&[MAC] and measuring <TXC line > of MAC side.
   >> 25MHz Clock comes out from PHY side, Clock does not come out from MAC,
        Voltage level decreases when connected to each other
 B) Ping communication between [PHY]&[MAC] is possible, but sometimes disconnection(MAC setting: RGMII)
  Picture B.1) when connecting <TXC line> between [PHY]&[MAC] measuring <TXC line>
    >> 25MHz clock comes outboth PHY & MAC
       So, Ping communication seems sometimes possible because the signal is overlapped,
       but there is a disconnection depending on the voltage level.
2. Review for RGMII vs MII
   1) RGMII : TXC(TxClock) go to from [MAC] to [PHY]
   2) MII : TXC(TxClock) go to from [PHY] to [MAC] > Our Case
3. Symptom prediction
    1) We suspect the setting forENET_TXC“ net(Ball no.: AG24) of i.MX8MM for MII modeseems to be wrong.
4. Request
    1) please sharea patch or SW guide for MII mode.
    2) please share the HW guide for MII mode.
