Background:
I met trouble during executing as
steps 。
Console fault message as follows:
“ MPC574xG Device detected. No breakpoints currently set. Disconnected from "127.0.0.1" via 127.0.0.1. Disconnection by port "16572" from 7224 Target Disconnected. ”
Whether the elf os is influential? My elf file os is MicroSA which from vector。
can you please share your elf file? If it is compiled for MPC5748G - it should work.
Jiri
