Switch project MCU from KL17 to KL13
josecarlos
Hi everyone,
I'm working with KL17 MCU in a custom board. Recently I've made a costdown board and I've changed KL17 for KL13 as MCU. I assumed that the code should work in the new MCU so when I tried to debug the performace it was impossible. I found to change the MCU at MCUXpresso setting in "Properties" but it neither work. Could anyone tell me what I'm doing wrong?.
Thank you and regards.
danielchen
Please check whether you can edit the MCU in project settings.
If this does not work, I would suggest download SDK for KL13 directly from
https://mcuxpresso.nxp.com/en/select
then merger your application to the new KL13 SDK, it is the safest way.
