Capacitive Sense in QN9080
cicerodomingosj
Hello everybody,
I need an application example that uses QN9080 with capacitive sense.
I took a look at SKD and found nothing about it.
Thanks in advance,
Cicero
  • QN
estephania_mart
The only information available for that it's the following application guide
Could you please check it and verify if that works for your needs?
Estephania
cicerodomingosj
Hello Estephania, thanks again.
I have already read these application notes. The problem is that the QN9080 SDK has no touch library. As mentioned in AN12190, there is an NXP touch library, but I didn't find it.
I need an example of how to integrate this functionality into a QN9080-based wireless application.
Thanks in advance,
Cicero
estephania_mart
Are you looking for all the files ? Or for some in specific?
Regards ,
Estephania
cicerodomingosj
Hello Estephania,
Thanks so much for the file.
Those files you sent me are just the TSI drives. The Touch library contains other files for the QN9080 solution.
I downloaded the MKE15Z256 SDK. Inside this SDK I found the NXP Touch library in the middleware folder. There are several other files needed to support the QN9080 touch feature.
So I need the complete and configured NXP Touch library for the QN9080. Can you help me?
Thanks in advance.
estephania_mart
Not sure those files are available to share anymore, I'll verify in case those are.
Etsephania
cicerodomingosj
Hello Estephania,
Those files you sent me are just the drives. The Touch library contains other files for the QN9080 solution.
I downloaded the MKE15Z256 SDK. Inside this SDK I found in the middleware folder the NXP Touch library. There are several other files needed to support the QN9080 touch feature.
So I need the complete and configured NXP Touch library for the QN9080. Can you help me ?
Thanks in advance.
Cícero Domingos Junior
VectorWork Automação Industrial
+55 41 99665-6375
cd.jr@hotmail.com
cicero@vectorwork.com.br
