FS8430 can not wake up
hongyuyan
Hi NXP Team,
I have a problem about FS8430.
when I give the BAT and wake signal to FS8430 at the same time,it can start up normally at the voltage from 8V ~ 36V.But when I  give the BAT at 9V first and then wake signal, FS8430 can not start up normally. At this condition, beside 8v~10V, FS8430 can start up normally.
I want to know what is the main reason.
Labels (2)
guoweisun
HI
Suggest your do experiment on debug mode then monitor your Vbat voltage directly in SBC VSUP1/2 pin and WAKE pins voltge.
