UART Parity Setting on IMX8MM
tom_orsi1
How do I find the register map for the UARTS on the IMX8MM? I reviewed the header files in the SDK and looked for specifics on the data sheet for the IMX8MM but I see no mention of the uart chip model?
I am specifically interested in knowing of the UART supports always set/clr on the parity bit?
Tom
CarlosCasillas
Hi Thomas,
The Parity enable and parity type are configured with PREN and PROE fields of UARTx_UCR2 register, described on chapter 16.2.13.4 of the i.MX8M Mini Reference Manual.
Hope this will be useful for you.
Best regards!
/Carlos
