Error loading .PCP file
jjr_net
hello:
     I has a problem when I download program to S32R274 with flash Debug way. Err message below:
;begin_cs device=$00F98000, length=$001E8000, ram=$40000000
Loading programming algorithm ...
Error loading .PCP file : C:\NXP\S32DS_Power_v2017.R1\eclipse\plugins\com.pemicro.debug.gdbjtag.ppc_1.8.3.201812312131\win32\gdi\P&E\nxp_s32r274_1x32x488k_cflash.pcp at address 40000060
Error loading programming algorithm - load aborted.
Error occured during Flash programming.
 But download program with RAM Debug is OK.
 IDE is "S32 Design Studio for Power Architecture Version 2017.R1".
 Please help me, thank you!
steven_mcgrath
The first thing I would try is to check to make sure that you have the most up to date plugin for S32 Design Studio, it seems yours may be a little older. To do so, navigate to the Help->Check for Updates and complete any necessary updates. Try restarting S32 Design Studio and perform the same test and see if you get the same result. I hope this helps!
Steve
jjr_net
hello, steve:
   According to you suggesetion,I updated S32, and the original problem has been solved.
thank you very much!
