EMC_Reset_Disable bit - where is it?
kbarker
The user manual UM10503 for the LPC43xx microcontrollers, in the External Memory Controller (EMC) chapter mentions the EMC_Reset_Disable bit, which controls whether or not parts of the EMC are reset during a warm reset.
However, there is no information on where the EMC_Reset_Disable bit is.
What is the address of the register that the EMC_Reset_Disable bit is in?
Which bit is it within that register?
What is the default (POR) value of the EMC_Reset_Disable bit?
soledad
Please check the EMC status register.
I hope this helps,
have a nice day!
Soledad
kbarker
Thank you for your reply, but it does not answer the question.
The EMC status register is read-only and there's no information on which bit (if any) is the EMC_Reset_Disable bit.
In other microcontrollers, there is (apparently) a ...
 "configuration bit in the SCS register, called EMC_Reset_Disable ..."
However, I can't find any information on where this is for the LPC4350.
