IMX8 Cross-compilation "unrecognized option '-Wl,-O1'"
1042484520
Dear NXP:
   为什么用yocto编译的IMX8的Tool chain不支持LDFLAGS="-Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed"的参数?
   在交叉编译内核的时候会报错:
   aarch64-fslc-linux-ld: unrecognized option '-Wl,-O1'
   aarch64-fslc-linux-ld: use the --help option for usage information
   scripts/Makefile.build:534: recipe for target 'drivers/firmware/efi/libstub/lib-ksyms.o' failed
   make[4]: *** [drivers/firmware/efi/libstub/lib-ksyms.o] Error 1
   scripts/Makefile.build:587: recipe for target 'drivers/firmware/efi/libstub' failed
   make[3]: *** [drivers/firmware/efi/libstub] Error 2
   make[3]: *** Waiting for unfinished jobs....
joanxie
1042484520
Hi Joan:
   unset CFLAGS CPPFLAGS CXXFLAGS LDFLAGS MACHINE
   上述unset操作是否会对内核的编译速度、优化程度造成一定的影响?
Thanks!
joanxie
to be honest, I'm not sure for this, I think unsetting these flags maybe affect the performance
1042484520
Hi Joan:
      那关于aarch64-fslc-linux-ld: unrecognized option '-Wl,-O1'问题有什么官方的解决方案吗?
Thanks!
joanxie
for using toolchain, suggest that you can use this as below:
Task #7 - Create the toolchain
https://community.nxp.com/docs/DOC-95225
