How to detect SPI PCS signal for MPC5746C?
fans
   Some devices may interpret SPI data after CS from low(active) to high.So TCF in SR register can't indicate if the whole SPI process has completed.
   I have to add a time filter although it's not a good solution, so is there any other solution or relevant flag to detect CS signal?
davidtosenovjan
Hi, could you please elaborate the question more in detail? I am not sure if I understand you. Thanks
fans
The transmission is considered successful only after CS from LOW to HIGH for this chip. In practice, I want to detect CS signal to judge whether the data received by device is actually processed.
Thanks for your reply.
davidtosenovjan
OK
You don't need to detect it. Use TFFF and/or RFDF flags to find out wheter it is needed to push/drain the data.
