S32K146 Single Step not stepping correctly
acrook
Can anybody advise as to why Single Step functions step-into and step-over both perform the same step-into function. Am I missing some setting somewhere?
Tags (3)
acrook
We're using our own project and its optimized code, is that the problem?
jiri_kral
yes, in some cases it may be an issue. For debugging purposes is better solution use non-optimized code.
Jiri
jiri_kral
can you provide more details like screenshots? Are you using some example or your own project? Did you enabled optimizations?
Jiri
