I am using HTRC110 to read some EM9100 cards. I noticed that there is always some garbage data stream on Dout line from HTRC110. Does anyone know why this is happening and is there a way to get rid of it?
Thanks in advance.
Dear Henry Wong,
Hope you are doing great, is it possible that you share more information about this issue, such as command logs or the procedure being followed?
Thanks a lot!
Jonathan
