We are experiencing audio playback underrun issues on the imx8mm, whereas the exact same application runs flawlessly under imx8mq. The observed CPU usage is low.
Any pointers at how to fix/troubleshoot this issue further.
Ali
Does this happen when you are reproducing a video with Audio? Are you reproducing Audio trought HDMI?
Diego
Hi Diego,
There is no video output and no HDMI either, this is a simple 2 channel i2s output to a digital amplifier.
Best,
Ali
Are you using Linux or Android?
If you are using Linux, could you please pass me the gstreamer pipe-line that you are using.
Diego
