tclap-1.2.1-r0 do_compile: oe_runmake failed
Question asked by Sam Wu on Aug 20, 2019
Latest reply on Aug 29, 2019 by gusarambula
I met an build ERROR about below message:
But I'm not sure what's the mean about this error message. Does any one could help on this? Thank you.
ERROR: tclap-1.2.1-r0 do_compile: oe_runmake failed
ERROR: tclap-1.2.1-r0 do_compile: Function failed: do_compile (log file is located at /home/samwu/NXP/build/tmp/work/aarch64-poky-linux/tclap/1.2.1-r0/temp/log.do_compile.4489)
ERROR: Logfile of failure stored in: /home/samwu/NXP/build/tmp/work/aarch64-poky-linux/tclap/1.2.1-r0/temp/log.do_compile.4489
| make[1]: Entering directory '/home/samwu/NXP/build/tmp/work/aarch64-poky-linux/tclap/1.2.1-r0/build/examples'
| aarch64-poky-linux-g++ --sysroot=/home/samwu/NXP/build/tmp/work/aarch64-poky-linux/tclap/1.2.1-r0/recipe-sysroot -Wall -Wextra -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/samwu/NXP/build/tmp/work/aarch64-poky-linux/tclap/1.2.1-r0=/usr/src/debug/tclap/1.2.1-r0 -fdebug-prefix-map=/home/samwu/NXP/build/tmp/work/aarch64-poky-linux/tclap/1.2.1-r0/recipe-sysroot= -fdebug-prefix-map=/home/samwu/NXP/build/tmp/work/aarch64-poky-linux/tclap/1.2.1-r0/recipe-sysroot-native= -fvisibility-inlines-hidden -Weffc++ -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -o test1 test1.o
| test1.o: file not recognized: File truncated
| collect2: error: ld returned 1 exit status
| Makefile:393: recipe for target 'test1' failed
| make[1]: *** [test1] Error 1
| make[1]: *** Waiting for unfinished jobs....
| test3.o: file not recognized: File truncated
| test4.o: file not recognized: File truncated
| test2.o: file not recognized: File truncated
| Makefile:449: recipe for target 'test3' failed
| make[1]: *** [test3] Error 1
| Makefile:453: recipe for target 'test4' failed
| make[1]: *** [test4] Error 1
| Makefile:437: recipe for target 'test2' failed
| make[1]: *** [test2] Error 1
| test5.o: file not recognized: File truncated
| Makefile:457: recipe for target 'test5' failed
| make[1]: *** [test5] Error 1
| test7.o: file not recognized: File truncated
| test8.oMakefile:465: recipe for target 'test7' failed
| : filemake[1]: *** [test7] Error 1
| test6.o: file not recognized: FileMakefile:469: recipe for target 'test8' failed
Sam
