Where can I modify the build thread on i.MX Yocoto Project
sam_wu
My computer will run the "make j 8" when use the bitbake build command.
But it will cause my computer hung after build image.
Where can I modify the build thread on i.MX Yocoto Project ?
Sam
Rita_Wang
Could you also send us your hung information when build?
sam_wu
I has build success after re-sync the imx-4.14.78-1.0.0 and rebuild it. Thank you.
Rita_Wang
Could you tell us which version BSP are you using? About build the BSP in Yocto, you can see the i.MX_Yocto_Project_User's_Guide document.
